How to Display fields on basis of catalog task
puneetgoels1
In my workflow, there are around 20 catalog tasks and there are 100 fields all together. I need to display selective fields on the basis of catalog task e.g. task 1 show 5 fields and hide others, task 2 show 10 fields and hide others and like wise.
How can it be achieved efficiently?
puneetgoels1
Correct Answer: Catalog UI Policy or UI policy do not work on the conditions on short description of task. It works only for catalog item variables and short description like fields be it at request item level or catalog task level in scoped application.
So the way to achieve it is write a UI policy at global level, put a condition for the catalog item and use the script to implement it
40 REPLIES 40
also you need to check that this restriction should not apply for all other catalog item task related to other catalog item. For that you can check the specific catalog item using GlideAjax
I tried but it is not working fine
SetDisplay does not work but SetVisible work
also getting errors like this
Display false not set on field u_application_name: cross-scope access denied.
Similar error for mandatory and Readonly as well
Share your script please
function onLoad() {
g_form.setDisplay('u_application_name',false);
g_form.setDisplay('u_Req_type',false);
g_form.setDisplay('u_vpc_name',false);
g_form.setDisplay('u_new_db_reqd',false);
g_form.setDisplay('u_nimbus_config_directory',false);
g_form.setDisplay('u_region_name',false);
g_form.setDisplay('u_app_source_rep_url',false);
g_form.setDisplay('u_app_node_name',false);
g_form.setDisplay('u_db_password',false);
g_form.setDisplay('u_del_proj_manager',false);
g_form.setDisplay('u_ecr_repo_name',false);
g_form.setDisplay('u_developer_network_ids',false);
g_form.setDisplay('u_aws_abbr_app_name',false);
g_form.setDisplay('u_comp_prog',false);
g_form.setDisplay('u_bapp_id',false);
g_form.setDisplay('u_r3_dns_names_from_services',false);
g_form.setDisplay('u_env_type',false);
g_form.setDisplay('u_exec_owner',false);
g_form.setDisplay('u_terraform_rep_url',false);
g_form.setDisplay('u_t_shirt_size',false);
g_form.setDisplay('u_splunk_shared_name',false);
g_form.setDisplay('u_app_team_assignment_group',false);
g_form.setDisplay('u_rds_terraform_repo_url',false);
g_form.setDisplay('u_poc',false);
g_form.setDisplay('u_db_name',false);
g_form.setDisplay('u_tax_code',false);
g_form.setDisplay('u_project_name',false);
g_form.setDisplay('u_validation_results',false);
g_form.setDisplay('u_terraform_log_config_name',false);
g_form.setDisplay('u_abr_service_name',false);
g_form.setDisplay('u_db_user_id',false);
var value = g_form.getValue('short_description');
g_form.addInfoMessage('Puneet :' + value.includes('Monitor Progress'));
if (value.includes('Create Initial Assessment'))
g_form.setDisplay('u_tax_code',true);
g_form.setDisplay('u_env_type',true);
g_form.setDisplay('u_project_name',true);
g_form.setDisplay('u_application_name',true);
g_form.setDisplay('u_bapp_id',true);
g_form.setDisplay('u_app_team_assignment_group',true);
g_form.setDisplay('u_aws_abbr_app_name',true);
g_form.setDisplay('u_region_name',true);
g_form.setDisplay('u_vpc_name',true);
g_form.setDisplay('u_abr_service_name',true);
g_form.setDisplay('u_new_db_reqd',true);
g_form.setDisplay('u_comp_prog',true);
g_form.setReadOnly('u_env_type',true);
g_form.setReadOnly('u_project_name',true);
g_form.setReadOnly('u_application_name',true);
g_form.setReadOnly('u_bapp_id',true);
g_form.setMandatory('u_app_team_assignment_group',true);
g_form.setMandatory('u_aws_abbr_app_name',true);
g_form.setMandatory('u_region_name',true);
g_form.setMandatory('u_vpc_name',true);
g_form.setMandatory('u_abr_service_name',true);
g_form.setMandatory('u_new_db_reqd',true);
g_form.setMandatory('u_comp_prog',true);
else if (value.includes('Monitor Progress'))
g_form.setDisplay('u_exec_owner',true);
g_form.setDisplay('u_poc',true);
g_form.setReadOnly('u_app_team_assignment_group',true);
g_form.setReadOnly('u_aws_abbr_app_name',true);
g_form.setReadOnly('u_exec_owner',true);
g_form.setReadOnly('u_poc',true);
else if (value.includes('Create AID') )
g_form.setDisplay('u_t_shirt_size',true);
g_form.setReadOnly('u_vpc_name',true);
g_form.setReadOnly('u_abr_service_name',true);
g_form.setReadOnly('u_new_db_reqd',true);
g_form.setReadOnly('u_t_shirt_size',true);
else if (value.includes('Create CI-CD Build Pipeline'))
g_form.setDisplay('u_app_source_rep_url',true);
g_form.setDisplay('u_ecr_repo_name',true);
g_form.setReadOnly('u_tax_code',true);
g_form.setMandatory('u_app_source_rep_url',true);
g_form.setMandatory('u_ecr_repo_name',true);
} else if (value.includes('Provision Cluster'))
g_form.setDisplay('u_terraform_rep_url',true);
g_form.setDisplay('u_r3_dns_names_from_services',true);
g_form.setDisplay('u_terraform_log_config_name',true);
g_form.setMandatory('u_terraform_rep_url',true);
g_form.setMandatory('u_r3_dns_names_from_services',true);
g_form.setMandatory('u_terraform_log_config_name',true);
else if (value.includes('Build Launch Config'))
g_form.setDisplay('u_nimbus_config_directory',true);
g_form.setReadOnly('u_terraform_rep_url',true);
g_form.setReadOnly('u_r3_dns_names_from_services',true);
g_form.setReadOnly('u_terraform_log_config_name',true);
g_form.setMandatory('u_nimbus_config_directory',true);
else if (value.includes('Request Developer AWS ID'))
g_form.setDisplay('u_developer_network_ids',true);
g_form.setReadOnly('u_developer_network_ids',true);
} else if (value.includes('Build CI-CD Deploy Pipeline'))
g_form.setReadOnly('u_nimbus_config_directory',true);
g_form.setReadOnly('u_app_source_rep_url',true);
g_form.setReadOnly('u_ecr_repo_name',true);
else if (value.includes('Configure Splunk'))
g_form.setDisplay('u_splunk_shared_name',true);
g_form.setMandatory('u_splunk_shared_name',true);
else if (value.includes('Configure AppD'))
g_form.setDisplay('u_app_node_name',true);
g_form.setReadOnly('u_app_node_name',true);
else if (value.includes('Create RDS Subscription'))
g_form.setDisplay('u_rds_terraform_repo_url',true);
g_form.setMandatory('u_rds_terraform_repo_url',true);
} else if (value.includes('Create DB Schema'))
g_form.setDisplay('u_db_name',true);
g_form.setDisplay('u_db_user_id',true);
g_form.setDisplay('u_db_password',true);
g_form.setMandatory('u_db_name',true);
g_form.setMandatory('u_db_user_id',true);
} else if (value.includes('Perform Rolling Deploy'))
else if (value.includes('Create AWS dashboard'))
g_form.setReadOnly('u_db_name',true);
g_form.setReadOnly('u_rds_terraform_repo_url',true);
else if (value.includes('Validate Sample App'))
g_form.setReadOnly('u_db_user_id',true);
g_form.setReadOnly('u_splunk_shared_name',true);
else if (value.includes('Modify Base Resources'))
else if (value.includes('Verify Final Design'))
g_form.setDisplay('u_validation_results',true);
g_form.setReadOnly('u_validation_results',true);
else if (value.includes('App Sign-off'))
g_form.setMandatory('u_validation_results',true);
Seems it is something to do with scoped application
see the link below
setVisible works, but setDisplay doesn't
