How to display Flow Variable in RITM and SCTASK ?
08-22-2022 03:08 AM
Hello Experts,
I am using two Flow Variables in a Catalog item flow designer. But even I can use the variable values in SCTASK, but the variable values are not showing in the variable section of both RITM or SCTASK. Can somebody please help me how to fix the issue?
Screenshots given below:
Flow Designer
Variable Section not visible in RITM
Satanik
Service Catalog
08-22-2022 03:21 AM
how are you showing variables on sc_task form via flow
share step screenshots
08-22-2022 06:46 AM
Hello Satanik,
If you are trying to show the 2 flow variables on the RITM and SC TASK form view then you cannot show the flow variables on the variable section on the RITM and SC TASK form. You can only show the Catalog Item variable under variable section on the RITM and SC TASK form.
If you are looking for Catalog Item variable then please check the user role or the form view once.
Please mark this helpful/correct, if it answer your question.
