How to display questions and answers in virtual agent
mania
I have few questions and answers list so i have created a topic 'General questions'. but i want to do the once we click on that topic it should display list of the questions then we click on any of the question it should display the answer.
How to achive? can anyone please help on this, It will be usefull.
Thanks!
@mania,
The value is the backend name for the block you are choosing. Prompt and response field shows the actual message of the block in bot conversation. Hope that helps.
I suggest you go through the learning plan for virtual agent in Dev site until the end so that you can develop VA topic better. Here is the site: https://developer.servicenow.com/dev.do#!/learn/learning-plans/xanadu/servicenow_application_develop...
If you go through this and complete hands on available in it, all your questions will be solved.
Check out this doc of all the screenshots. I am unable to post screenshots directly due to some issue.
If you found my response helpful, please mark it as Solution and Helpful.
Thanks and Regards,
Ehab
It feels good knowing I could help you with your query. Please mark appropriate response from above (doc file attached) as Solution. This will help me and the community.
Thanks and Regards,
Ehab
