How to display the info message on task level but not on catalog form
Asish1
We had a catalog form, after submission a RITM is created and catalog task, when we open the catalog task and selected a option in drop box a info message should be appeared..
so this info message should be visible in task level but not on catalog form
Asish
lukasz szumilas
in order to do that i would go into Catalog Task form right click -> Configure -> Client Script (to make sure we configure Client Script for this task form) just select  and create On Change Client Script.
Something like this:find_real_file.png
Ankur Bawiskar
members have already suggested to use Catalog Client script which applies on Catalog Task only
What did you start with and where are you stuck?
Hi @Ankur Bawiskar
Thanks for the reply!!
After checking only for catalog task it is working fine now
Asish
Kalyani Jangam1
Hi, Please refer below
Hi @Kalyani Jangam
It is working now.
Asish
