How to display the selected checkbox values in task short description
08-04-2020 09:59 AM
Hi Team,
I have a form that contains a checkbox values. For example:
On selection of the checkboxes, a task gets created using a run script in the workflow.
How to set the respective selected choice as "short description" in task form even if multiple choices are selected.
Kindly help!
Service Catalog
08-23-2020 11:33 PM
Hi Sujatha,
Hope you are doing good.
Did you get a chance to check on the solution provided to resolve your query?
If your query is resolved please mark appropriate response as correct & helpful so that this thread can be closed and others can be benefited by this.
07-28-2021 09:46 AM
Hi Ankur,
How to accomplish this requirement via flow designer?
We want to copy the only selected check box label.
08-23-2020 11:43 PM
Hello Sujatha,
Try below script:
var option = '';
if (current.variables.var1.toString() == 'true') {
option = option + "Application 1,";
if (current.variables.var2.toString() == 'true') {
option = option + "Application 2,";
if (current.variables.var3.toString() == 'true') {
option = option + "Application 3,";
if (current.variables.var4.toString() == 'true') {
option = option + "Application 4";
task.short_description = "User selected" + option;
Kindly mark my answer correct & helpful; if it's useful to you.
Thanks & Regards,
Pooja Devkar
DxSherpa Technologies Pvt. Ltd
12-05-2022 08:13 AM
Hi Pooja,
I have a similar question too! Hoping you can guide me. Working on a catalog item which uses the Workflow Editor to manage the Workflow.
There is a Multirow variable set that has 6-7 checkboxes.
The business wants the Task short description to display as 'Pre Validation of' + the value(s) of the selected checkboxes.
I would like to add the script within the Task Advanced script if possible.
So far what I had googled, did not seem to work. Hoping you can help.
Thank you in advance.
