How to enable mentions in a custom journal field.
04-01-2025 01:55 AM - edited 04-01-2025 01:56 AM
Can anyone please help on this, It will be useful.
Thanks!
04-01-2025 02:26 AM
For example: I have sending a confidential message to "abel tuter" so that message should be visible to that "abel tuter" only not all user if i imposanate to "abc" user that user should not see the message.
04-01-2025 03:25 AM
I don't believe that's feasible.
Why not use the Agent chat feature in workspace and 2 agents can connect with each other there?
04-03-2025 03:01 AM
Hope you are doing good.
04-01-2025 02:25 AM
are you saying if you enter @Abel this is my comment in that custom field, then only the comment should be displayed and the user mentioned should be removed?
but why?
I don't think you can control that.
04-01-2025 02:32 AM
The comments will be visible to all the users. You can't hide the visibility of comment only to the mentioned user.
Please mark my response as solution accepted for your initial question, so that it will be helpful for future readers.
regards,
Rohit
