How to enforce a 48-hour hold before closing a Change based on Planned End Date/Time?
Kishore47
Hi Team,
I’m working on a requirement to enforce a 48-hour closure hold on Change Requests and would appreciate guidance on the best-practice approach in ServiceNow.
Requirement details:
  • Users must not be able to move a Change to the “Closed” state until 48 hours have elapsed after the Planned End Date/Time.
  • The rule should apply to the following Change types:
    • Normal
    • Standard
    • Emergency
  • Until the 48-hour window is completed, the system should block the update and display a user-friendly error message, such as:
    “You cannot close this Change until 48 hours after the Planned End Date/Time.”
Thanks in Advance
Tejas Adhalrao
Hi @Kishore47  ,
Use a Business Rule (before update) on the change_request table.It runs server-side, so it’s enforced regardless of UI (Classic, Service Portal, API).Can block the update before it happens.Can show a friendly error message.
Condition:state changes to (Closed) AND type IN Normal, Standard, Emergency
    // Only for Normal, Standard, Emergency changes
    var changeTypes = ['Normal', 'Standard', 'Emergency'];
    if (changeTypes.indexOf(current.type.toString()) == -1)
    // Only when user is trying to move to Closed (state = 7)
    if (current.state != 7)
    // Calculate 48 hours after Planned End Date/Time
    var plannedEnd = current.planned_end_date; // Make sure this is the correct field
    if (!plannedEnd) {
        gs.addErrorMessage("Planned End Date/Time is missing. Cannot close the Change.");
        current.setAbortAction(true);
    var now = new GlideDateTime();
    var plannedEndDateTime = new GlideDateTime(plannedEnd);
    plannedEndDateTime.addSeconds(48 * 60 * 60); // add 48 hours
    if (now < plannedEndDateTime) {
        gs.addErrorMessage("You cannot close this Change until 48 hours after the Planned End Date/Time.");
        current.setAbortAction(true); // blocks the update
})(current, previous);
check your backend values  and repalce it
 If you found my solution helpful, please mark it as Helpful or Accepted Solution...!
thanks,
tejas
Email: adhalraotejas1018@gmail.com
LinkedIn: https://www.linkedin.com/in/tejas1018
Hello @Kishore47
I think my response also proved beneficial to you, you can accept multiple solutions 🙂
Warm Regards
Sumit
Technical Consultant
Tejas Adhalrao
Hi @Kishore47  ,
    if (!plannedEnd) {
thanks,
tejas
