how to fetch the incident attached with problem records through business rule?
jiu
Hi, you can write a BR on the problem record and you can fetch the records. However be careful if the no. of incidents are high in your system, then this could affect the performance of the system as well.
Create BR on problem record
When: Display
Select Advanced
// Add your code here
gs.info("problem number is"+current.number);
var inc = new GlideRecord("incident");
inc.addQuery("problem",current.number);
inc.query();
while(inc.next()) {
gs.info("Incident is "+inc.getValue("number"));
})(current, previous);
Kindly mark my answer as correct if this works for you.
19 REPLIES 19
Could you tell me if you are facing any error?
jiu
From incident record i created a problem . after placing the above code in problem it has to display the incident number from which it has ...
The code that i had given above will print the information in the log. Check what data are you getting in the log file.
Try this
 inc.addQuery("problem_id",current.sys_id);
 inc.query();
var incidents = []
 while(inc.next()) {
incidents.push(inc.number.toString());
 gs.info("Incident(s) is/are "+ incidents);
jiu
