how to fetch the incident attached with problem records through business rule?
jiu
Hi, you can write a BR on the problem record and you can fetch the records. However be careful if the no. of incidents are high in your system, then this could affect the performance of the system as well.
Create BR on problem record
When: Display
Select Advanced
// Add your code here
gs.info("problem number is"+current.number);
var inc = new GlideRecord("incident");
inc.addQuery("problem",current.number);
inc.query();
while(inc.next()) {
gs.info("Incident is "+inc.getValue("number"));
})(current, previous);
Kindly mark my answer as correct if this works for you.
19 REPLIES 19
jiu
inc.addQuery("problem",current.sys_id);
inc.query();
var incidents = []
if(inc.next()) {
incidents.push(inc.number.toString());
gs.addInfoMessage("Incident(s) is/are "+ incidents);
But its not matching with incident
please replace the line
with
inc.addQuery("problem_id",current.sys_id);
jiu
thanks 🙂
Did it work?
Please close this thread by marking the correct answer!
jiu
in Release , if I add Change request but getting some other record , can u help me in dis
var chg = new GlideRecord("change_request");
chg.addQuery("release_id",current.sys_id);
chg.query();
var change = []
if(chg.next()) {
change.push(chg.number.toString());
gs.addInfoMessage("Change(s) is/are "+ change);
