how to fetch the incident attached with problem records through business rule?
jiu
Hi, you can write a BR on the problem record and you can fetch the records. However be careful if the no. of incidents are high in your system, then this could affect the performance of the system as well.
Create BR on problem record
When: Display
Select Advanced
// Add your code here
gs.info("problem number is"+current.number);
var inc = new GlideRecord("incident");
inc.addQuery("problem",current.number);
inc.query();
while(inc.next()) {
gs.info("Incident is "+inc.getValue("number"));
})(current, previous);
Kindly mark my answer as correct if this works for you.
19 REPLIES 19
In the place of release_id use the field name on the change form that is relating to release
Sanjay Bagri1
Hi ,
you can use this code in Display buisiness rule.
    inc.addQuery("problem_id",current.sys_id);
    inc.query();
    while(inc.next()){
    //gs.addErrorMessage("Row count "+ inc.getRowCount());
    gs.addInfoMessage("Incident is :-  "+inc.number );
it will show you only how many incidents are participates in problem .
and it can do also through After BR .
Please remember it mark as correct and helpful
Sanjay Bagri
here these three incident are in problem
This is a incident see below file only those incident is showing in top
i hope this will help you .
in Release , if I add Change request but getting some other record , can u help me in dis
var chg = new GlideRecord("change_request");
chg.addQuery("release_id",current.sys_id);
chg.query();
var change = []
if(chg.next()) {
change.push(chg.number.toString());
gs.addInfoMessage("Change(s) is/are "+ change);
dvp
Hey
Any update on this?
If one of the responses provided above resolve your question, please mark the response as correct answer, so future readers can find solution easily.
