How to Generic flow using flow designer
09-23-2025 02:23 AM
I am trying to create flow using flow designer
In that i am creating catalog task
I want that the catalog task should take value from catalog definition of catalog item
How can i acheive this
09-23-2025 03:05 AM
you cannot dynamically select the catalog item in that "Template Catalog Item" field.
You need to select it manually.
09-23-2025 02:29 PM
This article shows how to use a generic flow for multiple Catalog Items, with a Catalog Task that includes all of the variables for that Catalog Item:
