How to get difference between two dates(Start date and End date) in the scoped application?
J P Rohini
Hi all,
i have tried this code, but dint work out,
var v1 = new GlideRecord('x_252275_video_video_table');
v1.query();
while(v1.next()){
var g1 = new GlideDateTime('start_date');
var g2 = new GlideDateTime('end_date');
var sub = new GlideDateTime.subtract(g1,g2);
gs.info('Testing'+' '+sub);
Output returns in this format:1970:11:21  8:00:54:06
But Output should be in this format: 1 year 11 months 12 days
Thanks in Advance
Any help is appreciated.
Satyanarayana C
Please check if this works for you.
function convertDaysToYearsMonthsDays (diff) {
  var str = '';
  var values = [[' year', 365], [' month', 30], [' day', 1]];
  for (var i=0;i<values.length;i++) {
    var amount = Math.floor(diff / values[i][1]);
    if (amount >= 1) {
       str += amount + values[i][0] + (amount > 1 ? 's' : '') + ' ';
       diff -= amount * values[i][1];
  return str;
var dur = new GlideDuration();
dur.setValue('2018-03-01 07:30:00');
var duration2 = new GlideDuration();
duration2.setValue('2020-06-10 10:35:00');
var answer = duration2.subtract(dur);
gs.info(answer.getDisplayValue());
// get the day part
var gd = new GlideDuration(answer);
gs.info(convertDaysToYearsMonthsDays(gd.getDayPart()));
The function convertDaysToYearsMonthsDays - is taken from internet.
16 REPLIES 16
Hi Satyach,
Thanks for the code.
Helped!
Megha Padale
Giga Guru
Adding to all above, you have to convert value into duration .
Refer below script
var start = new GlideDateTime('start_date');
var start = new GlideDateTime('end_date');
var dur = GlideDateTime.subtract(start, end);
var duration = dur.getNumericValue();
var durationSeconds = (duration/1000);//like this convert seconds into hour and months etc.
gs.info(dur.getDisplayValue());gs.info(durationSeconds );
If my answer helped you in any way, mark answer as helpful and correct.
Thanks and regards,
Megha
