How to get Json data from field through business rule.
Sai25
How to pull below Json data from a field. I am storing the Json data on form in a  particular field that is string field.
The below data is from  a catalog item details.
'sysparm_id': '0d08837237153000158bbfc8bcbe5d02',
'sysparm_quantity': '1',
'variables':{
'example_var1': 'at_and_t_mobility',
'example_var2': '500MB',
'example_var3': 'eighteen_months',
'example_var4': 'slate',
'example_var5': 'sixtyfour'
I want to get the variables and sysparm_id. How to get from a variables.
Thank You,
Sai.
hvrdhn88
Giga Patron
try now.
var json = {
'variables':{
var ab = JSON.stringify(json);
var op = JSON.parse(ab);
gs.print(op.sysparm_id);
gs.print(op.variables.example_var1); // this way you will get variables object details.
Sanket Pokharka
Kilo Explorer
hiii try like this
var json=new JSON();
var object= {
'variables':' ',
var data=json.encode(object);
return data;
