How to get record producer sys id into a variable set ?
shabbir5
I have a variable set in that created a variable called 'price' which is a single line text.( i want to use that variable set into multiple record producers)
for the variable price i want default value as sys id of that record producer.
i tried on degault value: , javascript:current.sys_id ,and producer.sys_id but no luck , please share if you have any idea on this.
Thank you
Shabbir
Raghav Sharma24
Giga Patron
Try with on load catalog client script:
g_form.setValue('price', g_form.getUniqueValue());
9 REPLIES 9
it worked for me in native and portal both
please share your client script and the script screenshot
@shabbir
Did you accidentally mark other answer as correct?
The answer I shared works well for both native and portal.
You can mark only 1 response as correct.
So please mark appropriate response as correct so that it helps future readers.
@shabbir
Refer below
I got the record producer sys_id in alert in both native and portal
Which you can then set in the variable
native
portal
Ashish Bansal
This works for this: javascript:current.default_value = current.cat_item;
