01-16-2026 03:56 AM
Good afternoon.!
We have ServiceNow-JIRA integration. We have a requirement, to get the payload that gets sent to JIRA from the Flow designer upon any Incident ticket updates? We need it as a JSON format. Is it possible to get it?
Please help.
@Ankur Bawiskar @Dr Atul - LNG @Viraj Hudlikar
01-17-2026 07:43 PM
Hello @AbdurRahmanSnow
As mentioned by Ankur, you need to check flow execution details
Open the Execution Details.
Click on the Create Issue (Deprecated) step.
Check the Runtime Values.
OR
You can follow below steps:
Navigate to System Logs > Outbound HTTP Requests.
Filter by Target Host (your Jira URL) or URL containing rest/api.
Open the record to see the Request Body, which contains the raw JSON sent to Jira.
If my response has helped you, hit the helpful button, and if your concern is solved, do mark my response as correct.
Thanks & Regards
Viraj Hudlikar.
01-20-2026 12:41 AM
Solution:
The best way to capture the payload in json format-
1. Set below system properties
glide.outbound_http.content.max_limit =1000
glide.outbound_http_log.override =true
glide.outbound_http_log.override.level = all
2. Reproduce the Incident update so the flow runs the JIRA action.
3. Go to system logs - outbound http logs - Filter by the JIRA instance host (e.g: domain.atlassian.net) or by the execution timestamp.
4. Open the entry and check Request tab and copy it, that is the JSON sent to JIRA.
01-20-2026 12:41 AM
Solution:
