How to get to catalog request using ATF
Troy25
Hey guys,
I am trying to test a catalog request using the Automated Test Framework (ATF).  I would like to validate some fields in the sc_request table after ordering a Catalog Item.  So I am wondering how to I open an existing request that I just created.
Steps used in ATF:
Impersonate User
Open a Catalog Item
Set Variable Values
Order Catalog Item
I can query the request item using the following:
I can also query the catalog task using
However, how do I query the request in the sc_request table so that I can then open up the form?
Thanks in advance
Troy
Oh Okay got it. Can you try this to get the REQ and open the REQ form-
Give Sys ID instead of Request in the Conditions-
Data pill chosen is-
Okay I am guessing "glide.sc.checkout.twostep" is set to 'true' on your instance. Can you check this property on 'sys_properties' table.
If that property is set to 'true', the ATF will not execute as expected as it is a known issue (https://hi.service-now.com/kb_view.do?sysparm_article=KB0695998)
Set that Property to "false" and re-run your ATF, it should work.
Let me know the result 🙂
Thanks so much shruthiub.  Worked a treat 🙂
Appreciate the help.
Priyanka Chandr
Mega Guru
Hi Troy,
Please have a look into this that will  help you in all way
https://docs.servicenow.com/bundle/orlando-application-development/page/administer/auto-test-framewo...
Kindly mark it correct and helpful if it is applicable.
Priyanka
Thanks Priyanka,
I had gone through this article but only shows how to open up a requested item, approval and tasks.  It doesn't actually open up the request.
Any other suggestions?
Troy
please select the Request field from the data picker of Order a Catalog item step to open sc_request record
Screenshot already mentioned in previous reply of shruthi
