How to have no radio button selected on catalog item variable on form load?
chooi
I have a mandatory variable of type Lookup Multiple Choice (ie create radio buttons using data from a table) on a record producer.
By default, the first radio button is selected on form load.
Is it possible to have no radio button selected on form load?
I have tried setting ‘Do not select the first choice’ option to true but this does not appear to work and I want to avoid adding a —None— radio button using ‘Include none’ in Type Specifications.
chooi
thanks Martin. I tried that however that appear to clear the sort order of the radio buttons. And if I click on the first radio button it sorts the radio button by name. For example, if the items in table are Yes (10), No (20) and Maybe (30), the radio button will appear as Yes, No and Maybe on load. After the clearValue, if I select Yes, the radio buttons will re-sort and appear as Maybe, No and Yes, so not ideal.
