How to hide a choice from showing in a dropdown?
astanley
I have a select box variable that is part of a variable set. This variable set is included in multiple catalog items, but I want to exclude one choice on the select box variable from showing only on one catalog item. Is there a way I can do this without scripting? I tried to create a UI Policy so that, that region (the choice I am trying to exclude) cannot be selected/is not visible, but I am unsure how to do this. Please advise!
Hi @adrienne
Couple of things you need to correct in your Script. Based on your screenshot, I have highlighted what changes you need to do by writing my comments in the image below:
If you ae not sure on what will be the value for choice then follow the steps below:
1) Open your catalog item on which this Variable is present.
2) After opening it, click on Variable Set Related List as shown below:
3) Now in this Variable Set open the Variable under Variable Related List which has the choice option as for example shown below:
Now open this variable record and here you can find the variable Name highlighted in red below and also the choice value which you need to use:
Shloke
Hi, I have added the recommended script, however the region is still showing. Please see attached
Hi @adrienne
Shloke
