How to hide a values of the Reference field using Script
Sudesh
i want to hide the certain locations of the Reference field to cnm_location table, Specific to one catalog item.
As the variable is in variable set using in multiple catalog items ,reference Qualifier will not work
how to achieve this by script?
Mahendra RC
Hello Sudesh,
You can create a new variable in your variable set for example catalog_item_id and then use the onLoad client script on your variable set to set the catalog ID in this variable:
g_form.setValue("catalog_item_id", g_form.getParameter("sys_id"));
then in your reference qualifier you can pass the catalog Item ID
javascript:new your_script_include_name().function_name(current.variables.catalog_item_id);
and in your script include then you can apply query based on the catalog item id and return the result. So in future if you receive a similar requirement for other catalog Item you can just update the query or script in your script include to return the data accordingly.
If my answer helped you in any way then please do mark it as helpful. If it answered your question then please mark it correct and helpful.
Musab Rasheed
You can simply hide this field on your catalog item and create a new field and apply reference qualifier. You can even do with existing variable set but it requires coding which is not required.
Musab
Mahendra RC
Hello Sudesh,
