how to hide the choices based on roles using ACL
07-20-2022 03:43 AM
I have a requirement where Retired, Leased, Missing status should not reflect in list view to users who does not have "asset" role.
For this, I am trying to create ACL.
Please help to disable the list edit for the same.
Lalitha
07-27-2022 02:29 AM
Please close the thread by Mark it ✅ Correct/helpful, if this solves your issue.
Pavankumar
07-27-2022 03:11 AM
Hi Lalitha,
its not possible with ACL although you can write a client script for Workaround check this link you can add the role condition in there.
How to hide a choice option from list edit
Mark Correct or Helpful if it helps.
