How to hide variable using catalog client script
zeerodger27
I have "computer" variable which is select box in that I have 3 options 1)None (which is coming from by selecting the include none check box) 2)laptop 3) desktop and I have "device" variable which is select box in that I have 4 options 1) lenovo 2) dell 3) asus 4) samsung
1) If the computer variable is none then device variable should not be visible
2) If the computer variable is laptop then device variable should show lenovo & dell options in the dropdown
3) If the computer variable is desktop then device variable should show asus & samsung options in the dropdown
I have tried with the below on change client script but it is not working
var deviceTypeField = g_form.getControl('device');
g_form.clearOptions(deviceTypeField);
if (newValue === 'laptop') {
g_form.addOption(deviceTypeField, 'lenovo', 'Lenovo');
g_form.addOption(deviceTypeField, 'dell', 'Dell');
} else if (newValue === 'desktop') {
g_form.addOption(deviceTypeField, 'asus', 'Asus');
g_form.addOption(deviceTypeField, 'samsung', 'Samsung');
g_form.setVisible(deviceTypeField, false); // I have written this for none
swathisarang98
Hi @zeerodger27 ,
I have tried the your code in my pdi it needs little bit of modification,
Please find the corrected code :
        g_form.setVisible('device', false); // to hide device while onload
    if (newValue == 'laptop') {
        g_form.setVisible('device', true);
        g_form.addOption('device', 'lenovo', 'Lenovo');
        g_form.addOption('device', 'dell', 'Dell');
		g_form.removeOption('device','asus');
		g_form.removeOption('device','samsung');
    } else if (newValue == 'desktop') {
        g_form.addOption('device', 'asus', 'Asus');
        g_form.addOption('device', 'samsung', 'Samsung');
		g_form.removeOption('device', 'lenovo');
        g_form.removeOption('device', 'dell');
        g_form.setVisible('device', false); // I have written this for none
Please mark this comment as Correct Answer/Helpful if it helped you.
Swathi Sarang
Yashsvi
Hi @zeerodger27,
please check below script:
    if (isLoading || newValue === '') return;
    var g_form = g_form || window.g_form;
    if (newValue === 'none') {
        g_form.clearOptions('device');
Thank you, please make helpful if you accept the solution.
Hi @Yashsvi ,
the device variable is not getting hide when the computer variable is none
and can you please explain the below line
swathisarang98
Hi @zeerodger27 ,
Swathi Sarang
