How to insert value into Prompt box in ATF (Automated Testing Framework) ( is it possible OR Not )
chanikya
when i click on UI action it will displays one Prompt box for user input, Now how can i pass value into Prompt box  In ATF.
Any suggestions recommended .
Ankur Bawiskar
@chanikya
Javascript prompt boxes, alert and confirm box cannot be tested via ATF
20 REPLIES 20
Nope. It seems this cannot be tested since the javascript popups are browser specific an ServiceNow client test runner won't be able to detect this
Neha Deshpande1
I am also facing the same issue. Any update on this in Orlando version?
If yes, please share the details.
Thanks and regards,
Neha Deshpande
Chris Bui
Giga Expert
The only way I have been able to work around this is to build in atf into the design of the catalog item or code. This way you can use a test step to set a hidden value and bypass the thing that is blocking you.
For example we have a variable set called "ATF Bypass" that we add to our catalog items when we want atf to bypass prompts. We then update any client scripts to check for the atf_bypass variable. Finally make sure atf has a step to set the atf_bypass flag.
@Chris Bui
it would be nice if you share the steps so that it benefits members
Ankur Bawiskar
@chanikya
