How to make a true/false (boolean) field mandatory?
chr_kluge
Hi everyone
Did some of you face the same problem?
In the change_request I would like to make "production_system" mandatory. As it is a True/False field and I don't want to change the type I tried to configured a choice list with none. But it isn't working either for the choice values "0" and "1" or for the values "true" and "false.
How can I achieve this?
Thanks a lot
Christina
Anurag Tripathi
Giga Patron
I dont get the requirement here. if you make the checkbox mandatory , outcome will always be true only. There cannot be a scenario where user can mark it false.
I think you should use a dropdown (select box) with yes/no/none values and make that as mandatory.
HI Anurag
The business case is: we don't want force in a certain workflow step the responsible user(s) to think about the flag.
And as you said for a flag the attribute mandatory makes no sense. But SNow decided to make it a boolean not me.
Christina
jadona
Giga Contributor
You can create an onSubmit client script, and set a code similar to:
if (g_form.getValue("u_checkbox")=='false'){
  alert(getMessage("Please, accept the terms and conditions by clicking the checkbox"));
  g_form.showFieldMsg('u_checkbox',getMessage("Accept terms and conditions"),'error');
  return false;
  g_form.hideAllFieldMsgs('error');
chr_kluge
Hi everyone
Thanks for your input
I think I have to create a custom field. I just hoped I could avoid it.
BR
Christina
Hi Christina,
        Can we make True/False Boolean field Mandatory. If yes How can we make it??
Manideep Nadimpelli.
