How to make bold letters in body of the notification message.
In my first run script activity have a scratchpad variable(workflow.scratchpad.msgFinal) where i am storing a result. Please refer below
After this run script activity i have a notification activity where i am printing the scratch pad variable in body of the mail. And it should be look like below. Bold & Underline. I have used <b> tag and <u> tag in runscript. But am not getting bold and underline format.
Is this can be achievable only by notification script?
Sirraj
yahh , tested it can be used, <b> and <u>  can be set using run script activity as well.
lets do one thing, would it be possible if you can break your string and hardcord some text and see if its setting correctly format or not.
19 REPLIES 19
It can be used.
i think the script which you have used, it can be recreate on your email script and you will do the same logic there in email script to get the exact output. and then call email script on your notification activity . give a try
I doubt whether i can recreate it or not in mail script. Cos i am giving input vcenter to a subflow (has orchestration powershell activities) and getting response from the subflow as a output to each vcenter whenever i loop.
Yes it worked. Thanks Harshvardhan, it can be achieve in run script itself.
@Ankur Bawiskar thanks ankur for your support too.
