How to make Contact type default to NONE in incident and ritm?
Naveen Kumar
The req is
the Contact type for Incidents defaults to None when a user opens/creates a new Incident on the Platform and
the Contact type for RITMs defaults to None when a user opens / creates a new record form on the Platform.
SumanthDosapati
Please do not post duplicate questions and make confusions.
You posted same question three times.
You can try below approach.
> Add the variable to variable set.
> Include variableSet in all required catalogs.
> Set the default value of variable as NONE in variable configuration itself.
> You can create an onLoad client script for that on variable set
> In UI Type : select as Service Portal
> Add this script
g_form.setValue('contact_type', 'PHONE');  //check backend values
Mark as correct and helpful if it solved your query.
Sumanth
Musab Rasheed
Tera Sage
If you are fine with my response, Please hit like and mark my response as correct if that helps.
Musab
