How to Open submitted catalog item by using ATF
gcs
I have submitted one catalog item through ATF, then i am trying to open submitted request by using out put variable in ATF but where is showing on error like as "you are not authorized to open record"  even though having ATF all three roles. Finally i am trying to open submitted request manually but that request number also not showing to me.
can any one help me how to open request through ATF.
Hi Emyrold,
How did you get on with this as we are looking to have test similar?
Sam
Dakker
I am wondering the same thing. Does anyone know?
Dakker
To do this you:
  1. Add a step Open an Existing Record after the Order a Catalog Item
  2. In the Open an Existing Record step set the
    1. table to "sc_request"
    2. Record to: <previous step [Order a Catalog Item]> and select document ID
That's it.
You're my hero for saving myself from pulling my hair since yesterday. Thank you! This works as you suggested.
