How to parse double quotes in Jain.stringify
pavan patil
Hi, I’m facing an issue with a record producer that is configured as a catalog item on the Employee Center portal. The form has a Description field, which is a free-text field.
The problem occurs when we enter text that contains double quotes. For example, if the user enters something like "test" in the Description field and submits the form, the request fails, and the incident is not created in the target instance.
This setup is part of our e-bonding integration between two ServiceNow instances. Normally, when a request is submitted through the record producer in the source instance, it creates an incident in the target instance. However, the integration only fails when the Description field contains double quotes.
When the Description does not include double quotes, the incident is created successfully in the other instance.
Could you please help me with this issue?
we are using the code in our script include :
JSON.stringify.replace(/“/g, ' ');
20 REPLIES 20
@pavan patil
are you sure it's failing only because of description?
In the past I was able to send double quotes via REST Message body
