How to pass previous values from business rules to script action in servicenow
18wj1a05d2
I am unable to pass previous values to script action from Business Rules. could you please help me.
Many thanks,
Raghuveer
MaxMixali
Pass Previous Values as Flow Inputs
In your Business Rule, explicitly pass the previous values as input variables to the flow:
Business Rule (Before/After Update):
javascript
    // Store previous values in an object
    var previousValues = {
        state: previous.state.toString(),
        assigned_to: previous.assigned_to.toString(),
        priority: previous.priority.toString()
        // Add other fields you need
    // Trigger the flow with both current and previous values
    var inputs = {
        current_record: current.getUniqueValue(),
        table_name: current.getTableName(),
        previous_state: previousValues.state,
        previous_assigned_to: previousValues.assigned_to,
        previous_priority: previousValues.priority
    sn_fd.FlowAPI.getRunner().trigger('your_flow_sys_id', inputs);
})(current, previous);
Then in your Flow Designer script action, access these as input variables:
javascript
inputs.previous_state
inputs.previous_assigned_to
Hello i hope that can help
If you find this answer useful, please mark it as solution accepted/helpful
Massimiliano Micali
