how to pass sys ids from script include to client script:
Sathwik1
There is a variable on a caltalog item named "IP" which is a reference field....I am stucked at client script...can anyone please help me...
Script Include
var Firewall_IP = Class.create();
Firewall_IP.prototype = Object.extendsObject(AbstractAjaxProcessor, {
    PopulatIPsBasedonLoc: function() {
        var Loc = this.getParameter('sysparm_location');
        var gr = new GlideRecord('ip_address');
        gr.addQuery('location', Loc);
        var answer = [];
        while (gr.next()) {
            answer.push(gr.sys_id.toString());
		return 'sys_idIN' + answer;
    type: 'Firewall_IP'
OnChange Client Script
    if (newValue == 'IP') {
        var grLocation = g_form.getValue('source_location');
        var ga = new GlideAjax('Firewall_IP');
        ga.addParam('sysparm_name', 'PopulatIPsBasedonLoc');
        ga.addParam('sysparm_location', grLocation);
19 REPLIES 19
Not via a client script. You'll need to handle the logic in the script include by checking the passed value and either returning nothing or your filter.
Not sure what you said, can you suggest me whether my requirement is possible or not... if possible can you please help me with the script
@Ankur Bawiskar @Shivani Singh
Hey Sathwik,
Check if you got the solution and if not then can you please explain me in one reply or another question. everything in consolidated format
Quite a long thread to go through
No, you can't achieve what you want via a client script. You have to use a reference qualifier to change what records are visible in a list collector or reference field.
	PopulatIPsBasedonLoc: function(location) {
		if(location != 'IP')return;
		gr.addQuery('location', location);
		var answer = [];
		while (gr.next()) {
	type: 'Firewall_IP'
