‎01-21-2025 12:44 AM
how to populate of catalog item variable info to ritm short description when requesting catalog item
‎01-21-2025 01:27 AM
try this
current.short_description = 'Variable value is ' + current.variables.variableName;
current.setWorkflow(false); // to avoid triggering BR
current.update();
‎01-21-2025 01:18 AM
after insert BR on RITM table provide script
try this
current.update();
‎01-21-2025 01:11 AM
Hi @AJAYKUMAR G ,
You can use Get catalog variables action to update your RTIM short description. Please see below SS.
Suraj
‎01-21-2025 01:12 AM
if you are using flow then check this link
Issue with setting short description with variables in flow designer
‎01-21-2025 01:13 AM
Create a Business Rule
When to run - Before, Insert
In script section add-
