How to prevent users from disabling system notifications under Preferences->notifications
10-11-2023 05:38 AM
Could anyone please help me how to send notifications to users even if system notification is disabled under user preferences in UTAH Version.
10-11-2023 05:58 AM
What do you mean with if we disabled the system notifications ?
Help others to find a correct solution by marking the appropriate response as accepted solution and helpful.
10-11-2023 06:00 AM
10-11-2023 06:05 AM
Hi @Venkat141,
Try this:
Force a notification to be sent (servicenow.com)
10-11-2023 05:55 AM
Hi @Venkat141
If Notification is disabled by particular user then email sent by instance will not be delivered.
It's better to ask them to enable , that's what I think is workaround.
ServiceNow Developer
- Socrates
10-11-2023 06:36 AM
But why you want to force it to users. @Venkat141 It is user experience by forcing it you are making it bad.
If my response proves useful, please indicate its helpfulness by selecting " Accept as Solution" and " Helpful." This action benefits both the community and me.
Topmate: https://topmate.io/atul_grover_lng [ Connect for 1-1 Session]
