How to raise a Routine change using Standard change templates
srikanthvk
Giga Expert
I have been trying to create a Routine change using standard change templates but was unsuccessful in doing so. I have looked at the StdChangeProcessor but couldnt find a way to tweak that.
I have also modified the standard change properties and have excluded the field Type from the from restricted change request values and have added the Type as Routine in my template. Unfortunately even this didn't work.
Can someone help me over here.
Srikanth Varma
srikanthvk
Giga Expert
Found the answer to this, need to make changes to StdChangeUtils script include.
Override the default change type to 'Routine'.
14 REPLIES 14
Hello Tee,
You just have to copy the Default Change Type and override it on StdChangeUtils script include
Thanks for your prompt response. I have some additional changes that I need to make to another function in the "StdChangeUtilsSNC" script. In that case, should I be just copying over the said function or the whole script?
Thanks.
You need to just override the function of your interest by creating function with the same name in the StdChangeUtils script include. As StdChangeUtils inherits everything from StdChangeUtilsSNC, all its functions are there by default but you have option to define some of them again and change their behavior.
I've tried to change the table which the standard change is created in but that does not seem to to have any effect. Any ideas? Is this even possible?
var StdChangeUtils = Class.create();
StdChangeUtils.prototype = Object.extendsObject(StdChangeUtilsSNC, {
  initialize: function(request, responseXML, gc) {
  StdChangeUtilsSNC.prototype.initialize.call(this, request, responseXML, gc);
  this.TABLE_NAME_CHANGE = "u_change_operations";
  *Add customer changes below
      type: 'StdChangeUtils'
Hey,
Sorry to revive an old topic, however, this is the only one around on the subject.
I am creating a new standard change type, let's call it standardv2.
I have tried what you have above, however, the change type is not working.
Is there anything else I need to do besides the change to the StdChangeUtils script include?
		this.DEFAULT_CHG_TYPE = "standardv2";
//DEFAULT_CHG_TYPE: "standardv2",
I have tried adding the default_chg_type in the two locations you see above, but neither work.  I have tried adding the type = standardv2 in the standard change properties as well, but no good.  The change type definitely exists.
Cheers, Brendan
