How to raise priority using a business rule
davidwood
I'm new to world of service now and was looking for assistance on a business rule.
I'd like to make is to a priority 2 incident is raised to priority 1 eight hours after being raised/opened as a p2.       I've tried many different tests within business rules but nothing seems to work (We are on Fuji)
When to run
When: Before
Order: 100
Filter Conditions
Active is true
Priority is 2 - High
Duration is   Days 0   Hours 8
Actions
Urgency to 1 - High
Impact to 1 - High
Priority to 1 - Critical
The closest out of the box business rule is Incident State Active on Assignment which I've been playing around with a bit as well.   Can someone offer some advice?
Change of approach. I built the list filter to get it the way I wanted, then copied the query and used it in the addEncodedQuery() method like this.
inc.addEncodedQuery('active=true^priority=2^sys_created_on<javascript:gs.hoursAgoStart(8)');
inc.query();
gs.log(inc.getRowCount() + ' records found');
while (inc.next()) {
  inc.priority = 1;
  inc.update();
I did not update your scheduled job or records.
19 REPLIES 19
Hi Ctomasi.
Any luck with investigating that code?
I've tried swapping Priority to Urgency and other items but the same "0 tables found" result display's.       I'm doing this all on a service now developer environment so I could possibly give you access to it if you like.
Sorry, I've been consumed with Knowledge16 for the past couple weeks. I've just requested to follow you. If you follow me back we can exchange credential information to that instance and I can take a look.
Thanks.
Hi Chuck,
No worries at all!   I'll send you over the details shorly, thanks for the help again.
inc.query();
  inc.priority = 1;
  inc.update();
Hi Chuck,
Yes! its working! its really working!! Had to tweek the code a little bit more in the end. For some reason you can override proirty in a business rule but in a script it appears urgency and impact have to be raised instead.
inc.query();
          inc.urgency = 1;
          inc.impact = 1;
  inc.update();
