‎05-18-2022 08:42 PM
When you see the role assigned to the User ID
Is there a way to tell which group the ServiceNow role was assigned to or personally assigned?
Multiple Versions
‎05-18-2022 10:51 PM
as ankur said you can directly visit group and check group members else from user profile in roles related list
Add the Inheritance Map field to the Roles related list on the user record... Click the link on any row. It will tell you if the role was inherited from a group and a map to which roles.
‎05-19-2022 10:49 PM
Did you mistakenly marked other response as correct?
Would you mind marking appropriate response as correct
I have shared the link but it's written by another community member.
You can go through the details there
‎05-22-2022 06:32 PM
I created another question.
If you are okay, please answer here.
I can give you the correct answer.
