How to remove leading and trailing spaces for a reference field for eg. Caller
05-06-2020 08:17 AM
Hi Everyone,
I am trying to remove/trim the leading and trailing spaces on a reference field eg. Caller.
Use case:
In the "Caller" field, if you have leading whitespace or trailing whitespace (say, from copy/paste function), it will fail to find the user. As a programmer, I always remove leading/trailing whitespace from user input to ensure proper matches in search routines. How can we achieve it on a reference field. Please help me out.
Reference Architecture
05-06-2020 08:18 AM
05-06-2020 08:32 AM
the reference field is not where user can type in free form text so removing leading and trailing spaces doesn't make sense
Also if they want to populate value in there they need to give proper value or use lookup icon and then select the record
09-15-2021 04:55 AM
Hope you are doing good.
If my response helped you please mark it correct to close the question so that it benefits future readers as well.
05-09-2020 01:12 AM
Is there any update on this? Is this question resolved or you need some more assistance.
Please consider marking appropriate reply as ✅Correct & 👍Helpful.
