How to replace string with another in variable while submitting a catalog item
User12975
Hi Mates,
I have an issue where in when a & is added in a variable of the catalog item its shown as &
I ant to replace it each time when catalg item is submitted ,
Hence created a script and used in business rule somehow does not seems to be working .
Can someone expert will help here ?
    var roc = current.variables.variable_name.getDisplayValue();
    roc = roc.replace(/&/g, "&");
    current.variables.variable_name = roc;
})(current, previous);
variable_name is the name of the variable
Tried the same in PDI & it works.
Did you still manage to apply logs & check for values received. Also, I am assuming BR is on RITM table.
Raghav Sharma24
Giga Patron
 var roc = current.variables.variable_name.toString()
Try using current.variables.variable_name, without display value. The replace function works on string.
Did you try to replace if after converting the variable to string?
