How to report average age (in days) of open RITMs for a catalog item
dd31
Hi team,
I’m trying to create a report (without using Performance Analytics) to find the average age (in days) of open RITMs for a specific catalog item.
My requirement:
  • Filter on specific catalog item
  • Consider only open / active RITMs
  • Show average age in days
FR
Looking for recommendations or examples on how others have achieved this without PA.
Thanks!
Hi @dd31
I doubt this can be done. Did you check if there is any OOTB (out-of-the-box) report available for the same?
Check this OOTB
https://INSTACNCENAME.service-now.com/now/platform-analytics-workspace/visualization-designer/26e30d...
I did, its not available
Did you check above link, might be get some idea. else not possible.
I checked it, and it’s not exactly what I’m looking for, but thank you for sharing the references.
Hi @dd31 ,
Du you have performance analytics available in your instance?
