How to restrict DATE field range upto 12 months from Current Date
chanikya
Hi
this script is working in ITIL view, not working in Portal
Onchange: expiry    UI type:All
var date=new Date(getDateFromFormat(g_form.getValue('expiry'), g_user_date_format));
var future_date=new Date(new Date().getTime() + 60*24*365*60000);
if(date>future_date){
g_form.showFieldMsg('expiry','Maximum allowed is 12 months from current date','error');
 alert('Maximum allowed is 12 months from current date');
g_form.clearValue('expiry');
Srikanth Suri1
Kilo Expert
Hi Chanikya,
Please find script below:
Script include:
Check = Client callable
var ClientDateTimeUtils = Class.create();
ClientDateTimeUtils.prototype = Object.extendsObject(AbstractAjaxProcessor, {
//Takes a Single Date/Time Field and returns its time difference from nowDateTime().
//params = sysparm_fdt (the first date/time field), sysparm_difftype (time based format to return result. See "_calcDateDiff" function comments)
getNowDateTimeDiff: function(){
var firstDT = this.getParameter('sysparm_fdt'); //First Date-Time Field
var diffTYPE = this.getParameter('sysparm_difftype'); // Date-Time Type to return the answer as. Can be second, minute, hour, day
var diff = gs.dateDiff(gs.nowDateTime(), firstDT, true);
var timediff = this._calcDateDiff(diffTYPE, diff);
//return "getNowDateTimeDiff: FIRST DT: " + firstDT + " -DIFFTYPE: " + diffTYPE + " -TIME DIFF: " + timediff;
return timediff;
//Diff the amount of time between two different Date/Time fields
//params = sysparm_fdt (the first date/time field), sysparm_sdt (second date/time field), sysparm_difftype (time based format to return result. See "_calcDateDiff" function comments)
getDateTimeDiff: function(){
var secondDT = this.getParameter('sysparm_sdt'); // Second Date-Time Field
var diff = gs.dateDiff(firstDT, secondDT, true);
//return "getDateTimeDiff: FIRST DT: " + firstDT + " -SECOND DT: " + secondDT + " -DIFFTYPE: " + diffTYPE + " -TIME DIFF: " + timediff;
return timediff;
//Takes your date/time field and returns the amount of time before now. A positive is time before now, a negative number is after now.
getDateTimeBeforeNow: function(){
var diff = gs.dateDiff(firstDT, gs.nowDateTime(), true);
//return "getDateTimeBeforeNow: FIRST DT: " + firstDT + " -DIFFTYPE: " + diffTYPE + " -TIME DIFF: " + timediff;
return timediff;
//Returns true if it is before now, and false if it is after now.
getDateTimeBeforeNowBool: function(){
var answer = '';
if (diff >= 0){answer = 'true';}
else {answer = 'false';}
return answer;
//Returns the Date/Time of right now.
getNowDateTime: function(){
var now = gs.nowDateTime(); //Now Date/Time
return now;
//Returns the Date right now.
getNowDate: function(){
var now = GlideDate(); //Now Date
return now.getLocalDate();
//Returns the Time of right now.
getNowTime: function(){
var now = GlideTime(); //Now Time
var modnow = now.getLocalTime().toString().split(' ');
return modnow[1];
//Takes a date/time field and adds time to it.
//params = sysparm_fdt (the first date/time field), sysparm_addtype (type of time to add - second, minute, hour, day, week, month, year), sysparm_addtime (amount of time to add based on the type).
addDateTimeAmount: function(){
var addTYPE = this.getParameter('sysparm_addtype'); //What to add - second (addSeconds()), minute (need to add conversion), hour (need to add conversion), day (addDays()), week (addWeeks()), month (addMonths()), year (addYears())
var addTIME = this.getParameter('sysparm_addtime'); //How much time to add
var day = GlideDateTime(firstDT);
if(addTYPE == 'second'){day.addSeconds(addTIME);}
else if (addTYPE == 'minute'){day.addSeconds(addTIME*60);}
else if (addTYPE == 'hour'){day.addSeconds(addTIME*(60*60));}
else if (addTYPE == 'day'){day.addDays(addTIME);}
else if (addTYPE == 'week'){day.addWeeks(addTIME);}
else if (addTYPE == 'month'){day.addMonths(addTIME);}
else if (addTYPE == 'year'){day.addYears(addTIME);}
else {day.addDays(addTIME);}
//return "First Date: " + firstDT + " -Time to Add: " + addTIME + " -Add Type: " + addTYPE + " -Added Time: " + day;
return day;
//Takes a glide date field and adds time to it.
//params = sysparm_fdt (the first date/time field), sysparm_addtype (type of time to add - day, week, month, year),sysparm_addtime (amount of time to add based on the type).
addDateAmount: function(){
var firstDT = this.getParameter('sysparm_fdt'); //First Date Field
var addTYPE = this.getParameter('sysparm_addtype'); //What to add - day (addDays()), week (addWeeks()), month (addMonths()), year (addYears())
var day = GlideDate();
day.setValue(firstDT);
if(addTYPE == 'day'){day.addDays(addTIME);}
return day;
addTimeAmount: function(){
var time = GlideTime();
time.setValue(firstDT);
if(addTYPE == 'second'){time.addSeconds(addTIME);}
else if (addTYPE == 'minute'){time.addSeconds(addTIME*60);}
else if (addTYPE == 'hour'){time.addSeconds(addTIME*(60*60));}
else {time.addSeconds(addTIME);}
var modtime = time.toString().split(' ');
//return "First Date: " + firstDT + " -Time to Add: " + addTIME + " -Add Type: " + addTYPE + " -Added Time: " + time;
return modtime[1];
//Private function to calculate the date difference return result in second, minute, hour, day.
_calcDateDiff: function(diffTYPE, seconds){
var thisdiff;
if (diffTYPE == "day"){thisdiff = seconds/86400;}
else if (diffTYPE == "hour"){thisdiff = seconds/3600;}
else if (diffTYPE == "minute"){thisdiff = seconds/60;}
else if (diffTYPE == "second"){thisdiff = seconds;}
else {thisdiff = seconds;}
return thisdiff;
Glide AJAx OnChange:
g_form.hideFieldMsg('field-name');
var onlyDate = g_form.getValue('variables.field_name');
var today = new Date();
try {
//alert('diff');
var ga = new GlideAjax('ClientDateTimeUtils'); || if you are working in scoped application use :: var ga = new GlideAjax('global.ClientDateTimeUtils')
ga.addParam('sysparm_name', 'getDateTimeDiff');
ga.addParam('sysparm_fdt', today);
ga.addParam('sysparm_sdt', newValue);
ga.addParam('sysparm_difftype', 'day');
ga.getXML(RESPONSE);
//alert('diff time');
catch(err){
alert("Error detected Client Script: UP3 - Insufficient time warning > " + err);
// alert('catch');
function RESPONSE(response) {
//alert('callback function');
if(answer > 365){
alert("Whoops! event cannot be pre-scheduled or initiated with a future date if a future date has been selected in the date fields.");
g_form.setValue('field_name ', '');
return false;
Srikanth Suri
11 REPLIES 11
Use :
g_form.setValue('v_date', "");
i have tried it, but not working............
