How to retire Configuration Item using Flow Designer
06-21-2024 03:31 AM - edited 06-26-2024 01:34 AM
I have created a catalog item where there is a field - Select CIs(List collector- cmdb_ci table).
When user select the CI/CIs then it will ask for approval and then the operational status of the selected CIs will set as Retired.
I created a Flow Designer,
after approver approves it will go to the Look up records
sys id will be the list collector value
then i am added for each loop .
But flow is not going inside for each loop.
Please help in this.
Sam
Service Catalog
06-21-2024 05:59 AM
Did you check the output of step 5? Are there results to update? What is step 6? What is the result there? Looking at what you do provide, it seems like there is an if in step 6 that doesn't return anything.
Check the executions what the input and output of the steps are. We are missing information to help and can only point you to where to look.
06-21-2024 06:36 AM
06-24-2024 01:06 AM
OK. And my other questions? What is step 6, what are your results? What do the flow executions say?
If you are returning sys_id's while you were looking for CI's in your step 5, there may be something wrong there, but you aren't sharing enough information to check on that.
06-26-2024 01:29 AM
