How to retire Configuration Item using Flow Designer
Samiksha2
I have created a catalog item where there is a field - Select CIs(List collector- cmdb_ci table).
When user select the CI/CIs then it will ask for approval and then the operational status of the selected CIs will set as Retired.
I created a Flow Designer,
after approver approves it will go to the Look up records
sys id will be the list collector value
then i am added for each loop .
But flow is not going inside for each loop.
Please help in this.
Sam
After execution  Look Up records:
