How to send approval based on RITM value?
lucky24
Hi Team,
I have one catalog item in which there is one select box variable with 4 choices value.
A- general  access 90
B - general  access 92
C - advance  access 90
D - advance  access 92
SO I have to send approval only when user select option C or D( advance  access 90 or advance  access 92)
I have created one notification on sysapproval_approver table but there In filter condition I am not able to dot walk on variable
Please help me here how can I achieve which code I need to write on advance condition So I can send approval based on the variable?
Vishal Birajdar
Hi @lucky24
Assuming you are using workflow.
You can use "If" activity in workflow and Click on Advanced and write a below script :
var myValue = current.variables.yourvariablename;
answer = ifScript();
function ifScript() {
//use your choice values
if ( myValue == 'advance access 90' || myValue == 'advance access 92') {
return 'yes';
return 'no';
and depending upon If activity you can divert the flow.
Vishal Birajdar
ServiceNow Developer
- Socrates
