How to Send ServiceNow Logs to External System for Ease of Searching and Analysis?
Arjun Kumar Le1
I have a requirement as shown in below screen shot, can any one let me know how to do it?
Harneet Sital
Hi @Arjun Kumar Lenka
You can use Splunk if your company has a subscription for the same.
Here is a similar thread - https://community.servicenow.com/community?id=community_question&sys_id=0e3a2e3adb3018d0f7fca851ca96...
Also, you can literally integrate ServiceNow with any reporting tool which would take a dump pf your logs into a tool and run analytics on it, for example Power BI.
Also, there is a ServiceNow Application that may help if you are to download these logs and want to manually feed them into some tools or review them, here this can he;p in that case - Use the log file browser
-Harneet Sital
Request you to please mark my answer as helpful or correct based on the impact
Find all my ServiceNow articles here
May I please know if the above has resolved your query? If so, please mark the answer as correct and helpful so the thread can be closed.
Harneet
