How to set choice values on form
03-16-2022 12:44 AM
Hi All, I have below business requirement
In my catalog form i have two variables
1. Target number - which is reference to target table
2. Complaint - as select box(yes/no)
if we select a target number in first variable as TGT1234(inside that " TGT1234 " form we have a field called "complaint " with data as 'test complaint')
My question is
if i select a target number in first variable and that number form has complaint field data i need to set the second variable complaint as yes and it should be read only.
if i select a target number in first variable and that number form has no complaint field data i need to set the second variable complaint as No and it should be read only.
How can we achieve this
03-17-2022 01:41 AM
Hi Ankur
tried with below script in ui policies with some filter conditions
var number = g_form.getReference('target_number', doAlert);
function doAlert(number) {
if(number.u_complaint_num!=''){
g_form.setValue('u_complaint', 'yes');
g_form.setReadOnly('u_complaint',true);
else{
g_form.setValue('u_complaint', 'no');
above script is setting NO value into second variable if the selected target record has no complaint data in the form
where as
above script is not setting YES value into second variable if the selected target record has complaint data in the form
03-17-2022 05:56 AM
try this and share
alert(number.u_complaint_num); // check what comes here
if(number.u_complaint_num!='' && number.u_complaint_num != undefined){
else{
04-06-2022 11:48 PM
@Nag
03-16-2022 12:59 AM
Hi Nag,
You can achieve it using below 2 methods
1. Catalog client script and a script include
2. Catalog client script with a getReference() function.
It's best to create a script include and call it in catalog client script using GlideAjax. In the script include you will be checking if the 'Complaint' field has a value or not.
03-16-2022 01:01 AM
Thankyou Vishnu,
Could you please provide the sample script as I'm not pretty good at script
