How to set multiple variable values in a single variable using Run Script(workflow)
Anusha25
After creating Request, few variables like,
variable 1 : A
                  B
                  C
                  D
variable 2: A1
                  B1
                  C1
variable 3:A2
                 B2
                 C2 etc
In Variable 4(multiple line text)the above 3 variable values should populate  with semicolon and space for each value.
29 REPLIES 29
Voona Rohila
Hi Anusha
You can use below logic in your runscript.
current.variables.<<multiline_variablename>> = current.variables.variable1 +" : "+ current.variables.variable2 +" : "+current.variables.variable3;
Mark it helpful if this helps you to understand. Accept solution if this give you the answer you're looking for
Kind Regards,
Rohila V
5x ServiceNow MVP
Tried ,not working
Hi anusha
Can you share the code you tried and also more info on what is not working.
Also keep logs in your run-script to check the variable values.
Kind Regards,
Rohila V
5x ServiceNow MVP
