How to set multiple variable values in a single variable using Run Script(workflow)
Anusha25
After creating Request, few variables like,
variable 1 : A
                  B
                  C
                  D
variable 2: A1
                  B1
                  C1
variable 3:A2
                 B2
                 C2 etc
In Variable 4(multiple line text)the above 3 variable values should populate  with semicolon and space for each value.
29 REPLIES 29
Your Workflow should be on RITM Table, you can use current.variables.variablename.getDisplayvalue()
what are the variable types of the 3 variables?
Mark it helpful if this helps you to understand. Accept solution if this give you the answer you're looking for
Kind Regards,
Rohila V
5x ServiceNow MVP
type of the 3 variables are multi line text
Can you share the expected output for below example?
Do you need your output as 1 : 2 : 3 : 1:...or 123 : 1234
Kind Regards,
Rohila V
5x ServiceNow MVP
Need to populate below values in 3rd variable (ad_group) in a single line format example: FEP_ALL; FEPMemberProdSrv; FEPClaimsProdSrv; INFEPApps-BU; Gag3papnas001a_dept_CORPCOL.GRO.1-RW etc
You can refer to this thread:
https://community.servicenow.com/community?id=community_question&sys_id=fb3a02cfdb9a3fc014d6fb2439961944
Sandeep
