How to set multiple variable values in a single variable using Run Script(workflow)
Anusha25
After creating Request, few variables like,
variable 1 : A
                  B
                  C
                  D
variable 2: A1
                  B1
                  C1
variable 3:A2
                 B2
                 C2 etc
In Variable 4(multiple line text)the above 3 variable values should populate  with semicolon and space for each value.
29 REPLIES 29
Hi ,i want to populate multiple variable values into one variable  and each value should be populated with semicolon and space.
Abhijit4
Answer mentioned by Rohila should work, could you please share your script and output with more details so that we can help you further.
Thanks and Regards
Abhijit
By marking my response as correct or helpful, you contribute to helping future readers with similar issues.
Abhijit
ServiceNow MVP
Murthy Ch
Hi Anusha,
Add getDisplayValue() and check.
Tested in BG script:
var gr=new GlideRecord("sc_req_item");
gr.addQuery("sys_id","7a5e0bef1b59cd10558d639bbc4bcb75");
if(gr.next())
gs.info(gr.variables.select_any_one.getDisplayValue());
Variable value in RITM:
O/p I got:
Hope it helps
Murthy
Murthy
Hi murthy,
need to populate multiple variable values into one variable with semicolon for each value .
Hi Murthy ,
the ouput  need to get in a single line with semicolon ?
please see the below attachment for reference
