‎04-29-2020 12:14 AM
We want to set the Quantity of catalog item based on a variable in the item.
We wanted to achieve this without using DOM (gel, $, j$, getElementBy, g_form.getControl, g_form.getElement)
Is there any way to achieve the functionality without using DOM
JAS
Service Catalog
‎07-24-2020 11:29 PM
Thanks for following up and for your valuable inputs.
I ended up stick with DOM. Yes I could have this validation in workflow and set the quantity in RITM but we are looking for more user friendly way of setting quantity and displaying that to user even before submission. Also we can't have more choices in quantity which is not looking great in classic view/native view of catalog items.
I came across one OOB API which may help others if they are looking to set quantity onchange of any variable in catalog item.
g_cart.setQuantity(10) ==> This API will allow us to set the quantity in UI itself, but the quantity choices should have the value that we are setting. Consider that the quantity choices are 1,2,3,4,5 in this case if we want to set 10 via g_cart.setQuantity(10) it wont work.
Once again thanks for the inputs and time.
JAS
‎05-03-2020 09:05 PM
Any update on this?
‎05-08-2020 07:27 AM
Hi
Yes good idea 🙂 Any update on this?
Have fun and BR
Dirk
JAS
