11-27-2020 01:22 AM
I have gone through several community threads and blogs, but I didn't find answer. I have a reference field on Table which is referring to "sys_user_grmember" table. By default it is showing the "sys_id" when I lookup through reference field, but I want to show the custom list view with only "user" column in the list. Is it possible to configure list for only this field.
I have tried using "sys_ref_list", but it effects globally. I also tried by configuring sys_popup view, but it is only effecting at the form level when we click on the info icon beside field.
Ajay
11-27-2020 01:38 AM
Hi Ajay,
I don't think you can set it only for this field
When you click the lookup it would show the sys_ref_list
That would be a global change.
Also marking User field as display=true would be a global change.
But if you are not using this table as Reference table in any of your existing tables you should be fine with making the dictionary change for User column as Display=true
07-14-2026 05:45 AM
Hi Ajay, you can achieve this by configuring the List elements.
Please go through this post and try to achieve this ServiceNow Learning 138: What does "sys_ref_list" list layout control?: ServiceNow Learning 138: What does "sys_ref_list" ... - ServiceNow Community
Let us know, if you came across any issues.
