How to Set the reference field dropdown with "blank" as the default value using business rule?
Divi
Mega Guru
So, I have a field "type" in "managed documents" module, where in i had made the type filed mandate but i also want to make the type field's default value as "blank" when creating a new record but if we click on the dropdown it  displays dropdown of other choices.(Also have removed none from dropdown).I have tried with onload client script but as its not a best practice, wanted to try with business rule.Any suggestions would be appreciated.
Thank you.
Hi Utpal,
I have tried that also but its displaying the sys_id of the choice.
Not sure how you do this since the Label and Value fields are mandatory
Ganesh Pardhe
Hello  Divi,
as per your requirement PFB,
https://docs.servicenow.com/bundle/geneva-servicenow-platform/page/administer/field_administration/t...
Hope this will help you.
Thanks and regards,
Ganesh
DXSHERPA
Hi Ganesh,
Actually that's not what i was looking for,please refer the below image to understand my requirement.
Thanks.
