05-12-2017 12:51 PM
I'm having an issue with getting help text to work on check box variables. Out of box there is a UI policy that is hiding the Show help (show_help) check box on the variable record. I updated that UI policy so I can check the Show help box to turn help text on. However, it still is not displaying my help text at all. I did some more research in the ServiceNow docs and the only information I could find is that help text is not available for check boxes and containers. Does anyone know why that is? And if there's a way I can do it anyways even though it's not out of box? I want to utilize HTML in the help text to display an image. I'm on Geneva.
Thanks for the help in advance!
Service Catalog
05-12-2017 12:56 PM
Looks like it is not supported for checkbox.
But you can always write onLoad scripts with show field message
g_form.showFieldMsg('field_name','Your help text','info');
07-14-2017 08:29 AM
It is not a good idea to use code like that. It will not be supported if you ever decide to use the Service Portal.
07-14-2017 08:54 AM
